Axminster Professional G Clamp - 75 x 50mm
- Strong rolled thread, smooth operation
- 75 mm x 50 mm – 2,844 N max clamping force
See the entire rangeIt’s a much quoted expression, but nonetheless true that ‘you can never have enough clamps’, so this range of Axminster G clamps ought to provide a sufficient quantity to avoid a shortage at a critical moment. Each features a strong rolled thread steel screw, live clamping pad and a tommy bar with which to apply pressure. They have a relatively slim cross section allowing you to place more clamps within a given length.
Lifetime guarantee.
Clamping Pressure | 290 kg |
EAN Barcode | 5052511072187 |
