Axminster Professional Pair of Clamp Supports
- Spare/replacement work supports
- For the Axminster HD Parallel Jaw Clamp
- Prevents work from direct contact with the bar, pack of 2
See the entire rangeThese supports fit the bar of the Axminster HD Parallel Jaw Clamp. Designed to lift the work slightly clear of the bar itself to avoid contact from glue etc. If you have lost yours in the shavings on the floor or require spares, these come in packs of 2.
EAN Barcode | 5052511119028 |
