Axminster Professional T-Bar Clamp
- Heavy duty, strong T-section bar, 20mm x 45mm in overall section
- Grey ductile cast iron head and tail, 50mm x 50mm clamp faces
- Twin start screw thread; max clamping pressure - 800Kg
UJK Air Wedge - Slim 100mmSpecial Price £10.38 £8.65 was £15.98 £13.32 Save £5.60 £4.67
See the entire range
These extra heavy duty clamps have strong 20 mm x 45 mm cold drawn steel bars. The T-section effectively eliminates twisting or bending under pressure. The bars also have a unique, chemically blackened surface to resist corrosion. The powder coated, ductile cast heads have 50 mm x 50 mm clamping faces. Other features are the twin start screw thread and 125 mm long tommy bar for fast adjustment countersunk holes in the base of the head allow for fixing to the bench if desired. Max clamping pressure - 800Kg.
Lifetime Guarantee.
Clamp Throat Depth | 50 mm |
Clamping Pressure | 800 kg |
