Purchase an Axminster Workshop lathe to benefit from this unique offer in store! The introduction will give you an understanding of the machine, including set up and safe usage, as well as what tools, accessories and materials are suited to your projects - so you can get on with the important decisions of what to make!
Immerse yourself into the wonderful world of woodturning
Perfect for the beginner, these essential tools we'll make it easy to kickstart your woodturning journey.
Axminster Clubman SK80 Woodturning Chuck Package
Carefully put together with the beginner in mind, this unique starter kit gives you the most useful woodturning accessories. It is packaged in a convenient storage box giving you a safe place to store your tools when not in use.
Start spindle and bowl turning with this great value for money, set of six turning tools. Perfect for the beginner, the tools each come correctly ground and ready sharpened meaning you can start turning straight out the box!
A must-have for any budding woodturner. Recommended by our own Skill Centre Tutors, the Woodturning Foundation book and DVD walks you through 12 step-by-step simple and effective projects. Gradually building your skills and confidence to help you become an accomplished woodturner!
If you have ever wanted to take up woodturning this lathe will meet all your needs and give you hours of turning enjoyment in your workshop. It is well suited to anyone with a limited budget or only enough space enough for a small lathe.
The AW240WL woodturning lathe features five spindle speeds, giving a useful range between 760 and 3,200rpm. It has a maximum bowl turning capacity of 240mm diameter and a spindle turning capacity of 440mm between centres.
The headstock, bed and tailstock are constructed of heavy cast iron, minimising vibration. The 375W induction motor has more than enough power for the lathe’s capacities and any projects that are likely to be undertaken. Both the headstock spindle and tailstock barrel take 2MT accessories, with the spindle nose having a 1" x 8tpi thread. The tailstock also has a hollow barrel to enable long hole boring.
Supplied with Axminster drive and revolving tailstock centres, 75mm diameter faceplate and 150mm tool rest.
N.B. The distance between centres will vary slightly dependent on the type of centres or accessories used.
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee may be void when used for business or educational purposes.
