Axminster Workshop AW305WL Woodturning Lathe - 230V
- Powerful 550W DC motor, quiet and smooth operation
- Variable speed from 500 to 4,080rpm
- Cast iron bed, headstock and tailstock provide rigidity, strength and years of pleasure
For the more ambitious beginner...
This bench mounted woodturning lathe offers excellent capacity, capabilities and power. The AW305WL has the convenience of variable spindle speed with electronic control. 
Buy with confidence
So sure are we of the quality of this lathe, we cover all parts and labour free of charge for three years! Find out more
Cast iron construction
The cast iron construction ensures stability and reliability. The bed is made from cast iron, helping to reduce vibration.
Axminster APF 10 Evolution® Powered Respirator with Impact VisorFrom £299.98 £299.98
Axminster Woodturning 150mm (6") Tool Rest with 16mm (5/8") PostFrom £10.88 £9.07
Power comes from a 550W DC motor providing full torque across the speed range. The spindle speed range is from 500 to 4,080rpm, with a choice of two belt ratios.
Made almost entirely in cast iron ensuring stability and minimal vibration during operation. The bed of this lathe has a finely ground top surface for smooth tool rest positioning. The spindle nose has a 1" x 8tpi thread and a 2MT taper. The tailstock barrel has a 2MT bore with 50mm of movement and automatic ejection of centres. Quick release levers allow for easy and accurate positioning of tool rest and tailstock. Solid rubber feet help to eliminate vibration.
Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
Distance Between Centres | 457 mm |
EAN Barcode | 5052511125371 |
Headstock Taper | 2 MT |
Lathe Speed | 500 - 2,040 / 1,000 - 4,080 rpm (var) |
Max Diameter over Bed | 305 mm |
Model | AW305WL |
Nett Weight | 40 kg |
Overall L x W x H | 970 mm x 280 mm x 440 mm |
Power | 550 W |
Rating | Home Workshop |
Spindle Thread | 1" x 8 tpi |
Tailstock Ram Travel | 50 mm |
Tailstock Taper | 2 MT |
Tool Post Diameter | 16 mm (5/8") |
Voltage | 230 V |
