Axminster Workshop AW318BT Benchtop Thicknesser - 230V
- HSS blades deliver 18,000 cuts/min, feed speed of 7m/min
- Depth capacity up to 153mm, maximum width 318mm
- Fold down table extensions with end rollers
Resharpenable HSS Planer Knives for JWP-12, MB1931, AC318BT & AW318BTFrom £28.98 £24.15
The Axminster AW318BT benchtop thicknesser is compact and more than capable of fulfilling the needs of the enthusiastic woodworker.
Its powerful 1,800W motor quickly removes material up to 2.5mm thick with each pass. The two resharpenable HSS blades give 18,000 cuts per minute; this coupled with the feed speed of 7m/min results in an excellent ripple free finish. The maximum timber thickness is 153mm with a maximum width of 318mm.
The front and rear fold down table extensions with end rollers provide support for longer boards. A 50mm diameter dust hood allows connection to a vacuum extractor. The motor has overload protection with a reset circuit breaker, and the NVR switch prevents accidental startup.
The AW318BT benchtop thicknesser is highly portable and perfect for preparing both hard and soft woods for all kinds of projects. Supplied with tools and a blade setting jig.
Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
Cuts per Minute | 18,000 |
Cutterblock Diameter | 48 mm |
Cutterblock Speed | 9,000 rpm |
Dust Extraction Outlet | 50 mm |
EAN Barcode | 5052511125357 |
Feed Speed | 7 m/min |
Knives | HSS (Resharpenable) x 2 |
Max Depth of Cut Thicknesser | 2.5 mm |
Max Thicknessing Height | 153 mm |
Max Thicknessing Width | 318 mm |
Min Extraction Airflow Required | 390 m³/hr |
Min Thicknessing Height | 5.0 mm |
Model | AW318BT |
Nett Weight | 30 kg |
Overall L x W x H | 600 mm x 360 mm x 480 mm |
Plug Fitted | UK 3 pin plug |
Power | 1.8 kW |
Rating | Home Workshop |
Voltage | 230 V |
