Axminster Workshop AW405SS V/Speed Scroll Saw - 230V
- Powerful DC brush motor with variable speed 550 to 1,600/min
- 406mm (16") throat allows larger projects
- Generous 410 x 254mm table tilts to 45° for bevel cutting
- Strong and robust cast aluminium table
The AW405SS is a great place to start your scroll sawing hobby.
Fitted with a powerful DC motor, the AW405SS variable speed (550 to 1,600/min) scroll saw easily copes with cutting a wide variety of materials up to 50mm deep. The two blade arms are independently pivoted giving a virtually straight up-and-down motion to the blade for a better quality cut.
A 35mm diameter dust port allows the scroll saw to be connected to a vacuum cleaner. A generous table (410 x 254mm) with a 406mm (16") throat, tilts to 45° for bevel cutting. The saw accepts pinned or plain end blades. The clamps are easily accessible for blade changing. A blower helps keep the cutting line clean and easily seen. When changing blades a quick release tension knob allows quick and easy change. The heavy cast iron base gives stability and ensures low vibration.
Supplied with eye guards and service tools. A wide range of either pinned or unpinned blades are available.
