Axminster Workshop No. 4 Smoothing Plane
- Designed for smoothing and surface finishing
- Handy size, a good general purpose bench plane
- Smooth, rounded and comfortable hardwood handles
- The most popular and commonly used plane
- Flat, ground sole for smooth, even surfaces
- 245mm(9.1/2") long with a 50mm(2") wide blade
The most commonly used plane in the workshop...
The No. 4 Smoothing Plane is best for smoothing, trimming and surface finishing.
Blade
Cryogenically treated, high carbon steel blade, with 25° bevel, providing excellent edge retention
Body
Ductile grey iron body, with a flat ground sole.
Adjustable
Adjustable mouth for fine or coarse work. The depth of the cut is controlled with a micro depth adjustment.
Y-lever
The Y-lever design prevents backlash and helps with micro blade adjustment.
Comfort
Hardwood tote and handle ensure the plane feels comfortable and sturdy in your hand.
Cap iron
The lever cap iron prevents shaving or tear out.
Chip breaker
Improved chip breaker design reduces vibration when plane is in use.
Lateral adjuster
The lateral adjuster ensures the plane is level offering uniform planings every time.
Axminster Workshop Centrotec Compatible Depth Adjustable Bit HolderSpecial Price £3.98 £3.32 was £6.98 £5.82 Save £3.00 £2.50
Axminster Workshop planes represent great value for home or professional use; whether in a workshop or out on site. A No.4 is a handy size and weight for finishing and final smoothing as well as a good general-purpose plane.
The blade is cryogenically treated high carbon steel offering excellent edge retention. It comes with a 25° bevel. The blade only requires honing before use (putting a 30° micro bevel on the edge can be done in less than a minute).
The plane’s main body is ductile grey iron with a flat ground sole. It features an adjustable frog allowing you to close the plane’s mouth for finer work. The ‘Y’ lever that helps control the depth is an investment casting for better engagement with the blade. The lateral blade control lever is the traditional ‘disc’ type rather than simple piece bent metal. The plane has a lever cap iron and solid brass adjusting nut. The tote and handle are hardwood.
Axminster Workshop planes are made to a good standard and quality and only require a minimum of initial preparation or fettling before your first thin shaving.
The sole of the No.4 is 245mm(9.1/2") long, the blade is 50mm(2") wide.
Nett Weight | 1.85 kg (4lb) |
Plane Blade Width | 50 mm (2") |
Sole Length | 245 mm |
