Axminster Workshop Set of 4 Drum Sanders
- Drum sanders for use in a pillar drill or woodturning lathe
- 4 diameters: 25.4mm (1"), 50mm (2"), 63mm (2.1/2") & 75mm (3")
- Includes 80 grit and 120 grit sleeves
Axminster Workshop Drum Sander Replacement Sleeves - 80 GritFrom £11.28 £9.40
Axminster Workshop Drum Sander Replacement Sleeves - 120 GritFrom £11.28 £9.40
This set of four, 75mm long sanding drums will help you get more use out of your pillar drill or woodturning lathe. The drums are a resilient rubber fitted with an abrasive sleeve. Turning the nut located on the base of each drum, slightly expands the rubber and secures the abrasive sleeve. The diameters are: 25.4mm (1"), 50mm (2"), 63mm (2.1/2") and 75mm (3"). Partially used sleeves can be removed and kept for use at a later date. The drums come with two sets of sleeves, 80 grit and 120 grit. Replacement sleeves are readily available. Each drum has a 12.5mm shank. Maximum recommended speed 1,500rpm.
Abrasive Backing | Cloth |
Bobbin Height | 75 mm |
EAN Barcode | 5052511127467 |
Shank Diameter | 12.5 mm |
