Blum CLIP-TOP 120 deg. Unsprung Hinge & Cruciform Mount Plate With Screws
717592
717592
- All metal nickel plated hinge, 120° opening angle
- Unsprung, designed to be used with a touch latch
- Tool-free door to cabinet assembly and removal
- 3-dimensional adjustment (with mounting plate)
- Height adjustment ± 2mm
- Supplied with a Nickel plated zinc die-cast cruciform with pre-mounted screws
Show more
Show less
An all metal nickel plated hinge with 120° opening angle. It is unsprung and designed to be used with a touch latch. Tool-free door to cabinet assembly and removal plus 3-dimensional adjustment (with relevant mounting plate). Supplied with a nickel plated zinc die-cast cruciform with pre-mounted screws. Height adjustment ± 2mm.
#AxminsterTools
