Bosch 15 Piece Router Cutter Set - 1/4"
107995
From £74.98 £62.48
1 Review
In Stock - Ready to dispatch
  • 15 of the most commonly used, router cutters
  • 1/4"shank cutters with quality TCT edges
  • For soft, hard wood and manmade boards
This router bit set from Bosch comprises 15 well chosen, high quality TCT router cutters. For anyone who owns a router that can take 1/4" shank cutters this is a handy set of 15 very useful bits. All 15 can be used in hand held routers, in routers fixed in tables.
Contents:
1 x 12° Dovetail cutter x 14mm(9/16") diameter
1 x 60° V-groove cutter x 16mm(5/8") diameter
1 x 4mm(5/32") bearing guided Slotting cutter x 32mm(1.1/4") diameter
1 x Bearing guided Rebating cutter x 32mm(1.1/4") diameter
1 x Bearing guided Roman ogee cutter 4mm(5/32") radius x 27mm(1.1/16") diameter
1 x Bearing guided Cove cutter 9.5mm(3/8") radius x 28.5(1./18") diameter
1 x Straight cutter 6.3mm(1/4") x 20mm(25/32") depth of cut
1 x Straight cutter 12.7mm(1/2") x 30mm(1.3/16") depth of cut
1 x Straight cutter 16mm(5/8") x 30mm(1.3/16") depth of cut
1 x 3.2mm(1/8") radius bearing guided Rounding over cutter x 19mm(3/4") diameter
1 x 6.35mm(1/4") radius bearing guided Rounding over cutter x 25.4mm(1") diameter
1 x 25° bearing guided Chamfer cutter x 25.4mm(1") diameter
1 x 45° bearing guided Chamfer cutter x 35mm(1.3/8") diameter
1 x 12.7mm(1/2") diameter Flush cutter with bottom bearing x 25.4mm(1")
1 x 16mm(5/8") diameter Flush cutter with top bearing x 25.4mm(1")
The flush cutters allow you to trim or follow a profile fixed above or below the workpiece.
The robust storage case also includes spare bearings and a hex key.
4.00 1
