Bosch 6 Piece Router Cutter Set - 1/4"
107994
From £37.38 £31.15
  5. Half Star
3 Reviews
In Stock - Ready to dispatch
  • Six of the best, highly useful router bits
  • 1/4"shank cutters with quality TCT edges
  • For soft, hard wood and manmade boards
This router bit set from Bosch comprises six well chosen, high quality TCT router cutters. For anyone who owns a router that can take 1/4") shank cutters this is a handy set of six very useful bits. All six cutters feature bearing guides and can be used in hand held routers, in routers fixed in tables and on straight or curved work.
Contents:
1 x 3.2mm(1/8") radius bearing guided Rounding over cutter x 19mm(3/4") diameter
1 x 6.35mm(1/4") radius bearing guided Rounding over cutter x 25.4mm(1") diameter
1 x 25° bearing guided Chamfer cutter x 25.4mm(1") diameter
1 x 45° bearing guided Chamfer cutter x 35mm(1.3/8") diameter
1 x 12.7mm(1/2") diameter Flush cutter with bottom bearing x 25.4mm(1")
1 x 16mm(5/8") diameter Flush cutter with top bearing x 25.4mm(1")
The flush cutters allow you to trim or follow a profile fixed above or below the workpiece.
The robust storage case also includes spare bearings and a hex key
4.70 3
