Bosch C430 Abrasive Discs 125mm (8 Hole)
AX19967
AX19967
- Hook and loop backing for quick and easy disc change
- Pre-punched for efficient dust extraction
- For hard/solid wood, Corian, paint, lacquer and softwood
Axminster Workshop Abrasive Belt Cleaner - Large (300 x 50 x 50mm)From £30.28 £25.23
Axminster Workshop Abrasive Belt Cleaner - Standard (210 x 40 x 40)From £13.68 £11.40
Show more
Show less
Re-usable abrasives with hook and loop backing for general purpose sanding applications. Suitable for hard/solid wood, Corian, paint, lacquer and softwood. All pre-punched for dust extraction through the base. Available in packs of five.
Abrasive Backing | Paper and Hook and loop |
Abrasive Disc Diameter | 125 mm |
Abrasive Type | C430 |
