Bosch GCM 12 GDL Axial-Glide Mitre Saw and GTA 2500 W Legstand - PACKAGE DEAL
717039
717039
Low Price
Special Price £1,369.98 £1,141.65
was £1,499.98 £1,249.98 Save £130.00 £108.33
19 Reviews
  • GCM 12 GDL mitre saw
  • Unique saw with large capacity and Axial-Glide system
  • 104mm maximum cut height, 341mm width at 90°
  • Axial-Glide system gives the smoothest possible saw action
  • 52° left and 60° right mitre cutting
  • Maintenance-free with sealed bearing
  • Integrated sliding work supports, left and right
  • All controls to the front of the machine
  • Dual laser-line, precision 'Freud' saw blade
  • Groove cutting function
  • Supplied with 60T TCT saw blade and quick clamp
  • 3 year warranty available (registration required)
  • GTA 2500 W Gravity Rise Mitre Saw Stand
  • Combined stand, workbench and transporter
  • Folding with saw fitting into a portable sack truck
  • Strong tool mounts hold mitre saws in place
  • Adjustable work supports either end with repetitive stops
  • Powder coated tubular steel base
  • Pneumatic tyres for easy transporting
  • 947mm height without saw fitted, height folded 760 x 711mm
  • Show More
Package comprises the GCM 12 GDL Mitre saw and the GTA 2500 W gravity rise mitre saw stand
A unique saw with a very special 'Axial-Glide' system that gives the smoothest, precise cutting action of any of the mitre saws on the market today. Guided by means of a glide arm, mounted on sealed bearings and made from robust die-cast aluminium, it is maintenance-free and guaranteed to be smooth and accurate running for a lifetime of cutting. It has large capacities and a wide angle range plus dual laser-line for precise line-up before cutting and groove function. The machine saves space as it can be positioned against a wall. All controls are at the front and the scales and positive lock handles make setting the machine easy. Fitted with integrated material supports right and left of the main table, it has a back fence with a total length of 1,016mm to give maximum work support. The glide system is lockable for transport.
GTA 2500 W gravity rise stand
Combines transport without the need for lifting, working with full support of workpieces beyond a machine base and storage. It is also very quick and easy to set up and breakdown. Two universal tool mounts allow a mitre saw to be secured (other similar items could be made to fit), whilst built into both ends of the top are adjustable supports with repetitive stops enabling long pieces of wood to be supported safely while cutting. The tubular stand construction gives a very sturdy working base, once folded it resembles a sack truck fitted with two 8" pneumatic tyres that make transporting, even over rough ground, a simple job. In set-up two levelling feet ensure stability. Supplied with 60T TCT saw blade and quick clamp
Warranty Bosch Professional 3 Year Warranty (Registration Required)
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
Registration required within four weeks of purchase. More information can be found on the Bosch warranty website and in the warranty conditions.
4.90 19
