Bosch GCM 12 SDE Dual Bevel Mitre Saw
101829
From £834.98 £695.82
16 Reviews
Low Stock - Ready to dispatch
  • Massive cutting capacity of 120mm x 400mm (with spacer)
  • Variable speed for cutting a wide variety of materials (110V is single speed)
  • SDS nut for tool free saw blade changes
  • Bevel cutting up to 47° on both sides
  • Laser line projects cut line across the workpiece
  • Pull out table extensions on both sides for extra support
  • 3 year warranty available (registration required)
The Bosch GCM 12 SDE professional dual bevel mitre saw guarantees precision and versatility. It offers a massive 120mm depth or 400mm maximum width of cut. The bevel and mitre cutting facility on both sides have indents at common angles. A laser line projects the cut line across your work-piece. Both sides of the table have pull out extensions to give extra support to longer workpieces. Variable speed control featured on the 230V option allows the cutting of a wider variety of materials. A well-designed dual dust extraction system helps keeps your working environment clean. The spindle lock combined with an SDS blade nut makes blade changes fast and tool-less. To achieve the maximum 400mm crosscut, a sacrificial base board is required. The integral carrying handle makes transportation easier and safer.
Warranty Bosch Professional 3 Year Warranty (Registration Required)
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
Registration required within four weeks of purchase. More information can be found on the Bosch warranty website and in the warranty conditions.
4.90 16
