Well designed this stand solves many problems combining, transport without the need for lifting, working with full support of work pieces beyond a machine base and storage, it is also very quick and easy to setup and breakdown. Two universal tool mounts allow a mitre saw to be secured (other similar items could be made to fit) whilst built into both ends of the top are adjustable supports with repetitive stops, long pieces of wood can be supported safely whilst cutting. The tubular stand construction gives a very sturdy working base, once folded it resembles a sack truck fitted with two 200mm rubber tyres that make transporting, even over rough ground a simple job, in set up two levelling feet ensure stability.
