Bosch T101B Jigsaw Blades Clean Wood Cutting
AX23411
AX23411
- For cuts 3 to 30mm thick
- Best for hard and soft wood, plywood and chipboard
- Clean splinter free cut
- Available in packs of 5 or 25
Show more
Show less
Hard and soft wood, plywood and chipboard up to 30mm thick, clean splinter-free finish.
Blade Type | HCS, Ground and Taper Ground |
Jigsaw Blade Length | 74 mm |
Jigsaw Blade Type | Clean Cuts |
Max Cutting Depth | 30 mm |
Tooth Pitch \ tpi | 2.67 mm \ 9.5 tpi |
#AxminsterTools
