Bosch T301CD Jigsaw Blades Deep Wood Cutting
900330
900330
- 65mm soft wood, chipboard, plywood and fibre board
- Supplied in packs of 5
Show more
Show less
65mm soft wood, chipboard, plywood and fibre board.
Blade Type | HCS, Ground and Taper Ground |
Jigsaw Blade Length | 91 mm |
Jigsaw Blade Type | Clean Cuts |
Max Cutting Depth | 65 mm |
Tooth Pitch \ tpi | 3.00 mm \ 8.5 tpi |
#AxminsterTools
