Bosch S1411DF Sabre Saw Blades Wood and Metal (Pkt 2)
952337
952337
- Long 300mm blade
- Wood and metal cutting
- Wood up to 250mm
- Sheet metal, pipes and profiles 5 - 60mm
- Suitable for wood cutting where metal may be present
- Supplied in pack of 2
Show more
Show less
300mm length blade for wood and metal. Cuts wood up to 250mm, sheet metal, pipes and profiles 5 - 60mm. Suitable for wood cutting, where metal may be present. Supplied in pack of 2.
Blade Type | Bi-metal, Milled and Side Set |
EAN Barcode | 3165140036139 |
Model | S1411DF |
Sabre Saw Blade Cutting Capacity | up to 250 mm |
Sabre Saw Blade Length | 300 mm |
Tooth Pitch \ tpi | 4.23 mm \ 6 tpi |
