Bosch S644D Sabre Saw Blades Fast Clean Cuts Wood & Plastic
300049
300049
- Fast, clean cuts up to 100mm
- Soft wood, hard wood, chipboard, plywood & plastic
- Supplied in packs of 2
Bosch S1531L Sabre Saw Blades Pruning & Green Wood (Pkt 2)From £7.18 £5.98
Show more
Show less
For fast, clean cuts in hard and soft wood, chipboard, plywood and plastic, up to 100mm.
Blade Type | HCS, Ground and Side Set |
EAN Barcode | 3165140007689 |
Model | S644D |
Sabre Saw Blade Cutting Capacity | up to 100 mm |
Sabre Saw Blade Length | 150 mm |
Tooth Pitch \ tpi | 4.23 mm \ 6 tpi |
