Bosch T118EFS Jigsaw Blades Stainless Steel Cutting (Pkt 5)
701876
701876
- Inox for stainless and other tough plate materials
- 1.5mm - 4mm thickness
- Bi-metal laser welded
- Longlife and break resistant
- Pack of 5
Bosch T101BR Jigsaw Blades Reverse Cutting For Wood (Pkt 5)From £7.58 £6.32
Bosch T101A Jigsaw Blades Acrylic & Perspex Cutting (Pkt 5)From £13.68 £11.40
Show more
Show less
To cut a thickness of 1.5mm - 4mm stainless plate as well as other tough materials. The bi-metal laser welded combination of HSC and HSS gives longlife with a high break resistance, the HSS tooth has 8% cobalt making it very robust and more heat resistant than standard blades, the special milled and wavy set on the tooth strip for optimum cutting.
Blade Type | Bi-metal, Milled and Wavy Set |
EAN Barcode | 3165140451857 |
Jigsaw Blade Length | 57 mm |
Max Cutting Depth | 15 mm |
Model | T118EFS |
Pack Quantity | 5 |
Tooth Pitch \ tpi | 1.40 mm \ 18 tpi |
