Bosch T313AW Jigsaw Blades Serrated Knife Edge (Pkt 3)
501700
501700
- Knife edge, very clean cut on soft materials
- Insulation, cardboard, carpet, leather and rubber
- Blade length 100mm
- Pack of 3
Bosch T101BR Jigsaw Blades Reverse Cutting For Wood (Pkt 5)From £7.58 £6.32
Bosch T101AO Jigsaw Blades Tight Curve Cuts in Wood (Pkt 5)From £6.68 £5.57
Bosch T101A Jigsaw Blades Acrylic & Perspex Cutting (Pkt 5)From £13.68 £11.40
Show more
Show less
Knife edge for cutting polystyrene, insulation materials, rubber, carpet, leather and many other soft materials. Blade length 100mm. Pack of three.
Blade Type | HCS, Ground |
EAN Barcode | 3165140045926 |
Jigsaw Blade Length | 100 mm |
Max Cutting Depth | 100 mm |
Model | T313AW |
Pack Quantity | 3 |
