Bosch Ultra Thin Metal Cutting Discs
- Ultra thin, power saving discs
- Metal fast cutting, suitable for stainless steel
- 115mm (1.0mm thick) and 230mm (1.9mm thick) diameters
- 115mm max 13,000rpm & 230mm max 6,650rpm cutting speed
- For cutting all ferrous metals at far greater speeds
Ultra thin metal cutting discs in 115mm and 230mm diameters which cut faster than conventional discs by virtue of their reduced thickness. The amount of removed metal is reduced, increasing cutting speed and reducing the heat generated. Particularly suitable for stainless steel. Recommended maximum cutting speed is 13,000rpm for 115mm grinders and 6,650rpm for 230mm grinders. The 115mm discs are 1.0mm thick whilst the 230mm discs are 1.9mm thick.
