Broadfix Precision Wedge Shim
506089
506089
- Very precise packing wedge, a host of uses, shim, level, space or pack out
- Work as a pair or in singles, serrated design for precision
- Rotproof and waterproof with a high compression strength
- 78mm length x 45mm width, tapering from 2mm - 9mm
- Supplied in pack of 100
Show more
Show less
These wedges give a very precise packing height to level, shim and pack. Working as a pair, the serrated design gives the packers virtually a locking effect so once in place they will not slip. Rotproof and waterproof with high compression strength, you can use these almost anywhere. 78mm length x 45mm width, each tapering from 2mm - 9mm. Supplied in pack of 100.
#AxminsterTools
