Chroma Craft Peel-Off Stencils
- Create and develop your own artistic designs
- Peel-Off stencils, self-adhering highly flexible film
- Precision die-cut, reuseable, suitable for dye or paint
Stencils to make a statement
Challenge your creativity with the Peel Off stencil range from Chroma Craft. Part of the Nick Agar signature series of finishes, these stencils enable you to add beautiful textures and patterns to your pieces.
Wipe clean and reusable
Use again and again and create endless patterns for a unique finish to your projects. The stencil material is designed for use with low saturation solvent or acrylic paints. The self-adhering flexible film will conform to complex shapes and can be repositioned for maximum flexibility in creating your designs.
Precise patterns
The precision cut patterns are available in a range of popular designs including butterflies, leaves, fish and more. Use on their own or with the complimentary Infil Stencil range; layer colours and watch your designs take shape through the translucent stencil film. With both negative and positive images provided, you can let your imagination run wild!
Get creative
These stencils can be used with any combination of techniques including airbrush, dauber or roller with dyes, paints and markers. Use with Nick Agar’s Signature Series of wood dyes and markers for an excellent finish.
Chroma Craft Monarch Butterfly Infil™ StencilSpecial Price £14.99 £12.49 was £29.98 £24.98 Save £14.99 £12.49
Chroma Craft Forest Shadow Texture Mesh Infil™ Stencil - 2 PackSpecial Price £19.46 £16.22 was £42.68 £35.57 Save £23.22 £19.35
Chroma Craft Sugar Maple Infil™ Stencil - 2 PackSpecial Price £19.18 £15.98 was £42.68 £35.57 Save £23.50 £19.58
Chroma Craft Red Maple Infil™ Stencil - 2 PackSpecial Price £18.70 £15.58 was £42.68 £35.57 Save £23.98 £19.98
Chroma Craft Forest Shadow Texture Mesh Large Infil™ StencilSpecial Price £18.98 £15.82 was £42.68 £35.57 Save £23.70 £19.75
Chroma Craft Swallowtail Butterfly Infil™ StencilSpecial Price £15.37 £12.81 was £29.98 £24.98 Save £14.61 £12.17
Axminster Workshop Centrotec Compatible Depth Adjustable Bit HolderSpecial Price £3.98 £3.32 was £6.98 £5.82 Save £3.00 £2.50
Chroma Craft Peel-Off Stencils are part of the Signature Series by woodturner Nick Agar. Chroma Craft has worked closely with Nick to design and produce these stencils to help you develop your own artistic designs.
The stencil material is specially formulated for use with low saturation solvent or acrylic paints. It is a self-adhering flexible film that can conform to complex shapes and can be repositioned. Simply peel off from the backing sheet and apply to the surface that you want to colour. They are precision die-cut and reusable so you can use them again and again. The translucent film allows clarity for layering techniques as well as visibility of the pattern.
The stencils can be used with any combination of techniques including airbrush, dauber or roller with Chroma Craft dyes, paints and markers.
Each stencil pack contains both positive and negative images so you can have a lot of fun creating your own designs. Each stencil sheet is approximately 200 x 275mm with multiple sized cut-outs (approx. 10 per sheet), 2 sheets per pack.
