Clifton 3110 (3-in-1) Shoulder Plane
107493
107493
- Use as a shoulder, rebate or chisel plane
- Micro-adjustable blade for complete control of depth of cut
- Supplied with shims for adjusting the width of the mouth
Show more
Show less
This Sheffield made shoulder plane is unrivalled in quality and versatility. The Clifton 3110 can be used as a shoulder, rebate or chisel plane. The plane features micro-depth adjustment for taking the finest shavings. Two shims are provided for adjusting the mouth when used in conjunction with the bull nose or shoulder end piece. Shims are precision ground 0.8mm(1/32") and 0.4mm(1/64"). Overall length 152mm(6"). Cutter 28.5mm(1.1/8") wide.
Nett Weight | 900 g |
Plane Blade Width | 28.5 mm (1.1/8") |
Plane Sole Length | 152 mm |
Plane Type | Shoulder |
#AxminsterTools
