Crown Mini Carbide Pro Replacement Diamond Cutter
107578
107578
- Replacement tip for the Crown Mini Carbide Pro Detail Tip Turning Tool
- Solid tungsten carbide hardened to HRC 93; ultra long lasting
- 38mm x 9mm diamond shape
Crown Set of 6 Tools for Axminster Woodturning Micro HandleFrom £89.88 £74.90
Crown Mini Carbide Pro Detail Tip Turning Tool - UnhandledFrom £51.78 £43.15
Show more
Show less
A 38 x 9mm diamond shaped, replacement or spare tip for the Crown Mini Carbide Pro Detail Tip Turning Tool. The tip is solid tungsten carbide made from the finest nano-particle carbide, hardened to an unbelievable HRC 93; making it ultra long lasting.
British Made
EAN Barcode | 5052511124244 |
