DeWALT DCW220NT-XJ Brushless Belt Sander 18V (Body Only)
- 75mm width of belt
- Pre settable variable speed
- Flush sanding on one side
- Brushless motor
- Efficient dust extraction via bag or vacuum
- Body only and supplied in T stack case.
Axminster Workshop Abrasive Belt Cleaner - Standard (210 x 40 x 40)From £13.68 £11.40
The cordless DCW220NT belt sander is part of the DeWALT 18V system. Thanks to the brushless motor, it offers efficiency and durability. The 75mm wide belt is suitable for a range of sanding applications, such as table tops and other larger flat surfaces. It can also be used across the grain to help flatten slightly uneven boards, whilst removing waste quickly and easily.
Fitted with variable speed, the five pre-sets make it easy to change the speed, depending on the belt grit and sanding task. Compact in size with a soft grip for comfortable handling. The machine is supplied with a dust bag, but can also be used fitted to a vacuum extractor with the supplied adaptor (34mm internal, 42mm external).
Supplied with: Dust bag, extraction adaptor, sanding belt (75mm x 533mm), T-Stak storage case.
This is a body-only machine, supplied without batteries or charger but is part of the Dewalt 18V system.
The product must be registered by the original DEWALT Product user within 4 Weeks of Purchase by visiting the DEWALT website (DEWALT Product user contact details, tool catalogue number, serial number and date code required). Kits comprising a range of tools are excluded from registration, but individual tools from kits must be registered.
For full terms and conditions click here.
In order to make a claim, you will need to submit proof of purchase to us or an authorised DEWALT repair agent, and the product must display the CE mark.
*Some products are excluded from the 3 year guarantee. A detailed summary of individual product guarantees is available on the DEWALT website.
Abrasive Belt Size | 75 mm x 533 mm |
Belt Speed | 198 to 320 m/min |
Corded or Cordless | Cordless |
Dust Collection | Dust Bag Supplied |
EAN Barcode | 5035048793848 |
Model | DCW220NT |
Nett Weight | 3.46kg without battery |
Plug Fitted | None |
Sound Power Level LwA [Uncertainty K] | 90 dB(A) |
Sound Pressure Level LpA [Uncertainty K] | 82.2 dB(A) |
Vibration Sanding [Uncertainty K] | 3.5 m/s² [1.5 m/s²] |
