Dremel 3000 1/25 Rotary Tool, Flex Shaft with 25 Accessories
- Compact and powerful for a host of tasks
- Comfort grip for handling and control
- Easy fit Flexishaft with slim precise handpiece
- 10 stage variable speed, 10,000 - 33,000rpm
- Collect chuck, EZ Twistâ„¢ lock for easy change of accessories
- Vast range of accessories available
- Supplied in an organiser case with 3.2mm collet, 25 accessories & Flex Shaft
PROXXON 13 Piece Modeller's SetFrom £14.68 £12.23
A truly universal kit, Dremel 3000 high speed multi-tool is supplied complete with a flexible shaft and 25 accessories packed into a strong storage case. Covering a very large range of projects, these precise tools have a slim grip for easy control and can cope with a host of tasks: engrave, cut, grind, carve, sand, polish and route. A very large range of accessories is available. The main feature is the EZ Twistâ„¢ nose cap to tighten and loosen collect (no spanner required) ensuring a positive lock, whilst variable speed offers great control for whatever task the tool is put to. The flexible shaft allows fingertip control with precision for detailed work and hard to reach places. With an overall length of 1,070mm and 127mm bend radius it simply attaches to the 3000 tool. 2 year warranty. Accessories include a SpeedClic system, cutting, polishing and grinding tools. The kit is supplied with 25 accessories, Dremel flex shaft and storage case.
Chuck Capacity | 0.8 mm to 3.2 mm |
Chuck Type | collet |
Corded or Cordless | Corded |
EAN Barcode | 8710364060894 |
Model | 3000 1/25 |
Motor Power | 130 W |
Nett Weight | 0.51 kg |
Plug Fitted | UK 3 pin plug |
Rating | Home/Light Trade |
RPM | 10,000 - 33,000 rpm |
Sound Power Level LwA [Uncertainty K] | 88.1 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 77.1 dB(A) [3.0 dB] |
Vibration [Uncertainty K] | 12.8 m/s² [1.5 m/s²] |
Voltage | 230 V |
