Dremel 4250 3/45 Multi-Tool with Accessories
- Multi tool by name multi purpose by nature
- Powerful 175W motor with variable speed control
- Kit contains everything to get started right away
PROXXON 13 Piece Modeller's SetFrom £14.68 £12.23
The Dremel 4250 multi tool comes with a host of accessories and a sturdy storage case. There’s plenty here to get you started right away on a variety of tasks and projects. Attachments include rotary shield/guard (550), flexible shaft (225), straight fence/circle cutting guide (678) and wall mounted storage case.
The accessories in this kit cover engraving, carving, grinding, sharpening, sanding, cleaning and polishing. With its high power 175W motor with electronic feedback the 4250 maintains maximum performance whatever the task. The variable speed from 5.000 – 35.000 puts you in control. The ergonomic textured rubber soft grip makes for easy handling and reduced vibration means greater comfort when used for longer periods.
Chuck Capacity | 3.2 mm |
Chuck Type | collet |
Corded or Cordless | Corded |
EAN Barcode | 8710364082612 |
Model | 4250 |
Motor Power | 175 W |
Nett Weight | 600 g |
Plug Fitted | UK 3 pin plug |
Rating | Home/Light Trade |
RPM | 5,000 - 35,000 rpm |
Sound Power Level LwA [Uncertainty K] | 83.5 dB(A) [2.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 72.5 dB(A) [2.0 dB] |
Vibration [Uncertainty K] | 14.1 m/s² [1.5 m/s²] |
Voltage | 230 V |
