Easy Wood Tools Mid-Size Easy Turning™ Set 3-Piece
- The perfect go-to tools for bowls, platters, boxes and spindles
- No need to sharpen;, simply rotate cutter to a fresh edge
- Solid carbide replaceable tips keep an edge many times longer than HSS
- Use to turn dry or green wood, acrylics and resin
- 8mm square section bar ensures the tool sits flat and steady
- American Maple handle with copper ferrule for strength
- Easy Wood Tools are 100% made in the USA
Easy Wood Mid-Size Easy Tools offer great versatility when it comes to turning bowls, platters, boxes, and other projects. These are the perfect go-to tool
This 3-piece set comprises one of each tool:
The Easy Wood Mid-Size Easy Rougher has a square cutter, it removes material quickly, cleanly and efficiently.
The Easy Wood Mid-Size Easy Finisher with its round cutter, produces coves, hollows, sweeping curves and aids final shaping.
The Mid-Size Easy Detailer helps create small coves, beads, and other fine details. It has a diamond shaped cutter.
Each tool has a 350mm long handle is American Maple with a copper ferrule for strength (the tools have different coloured handles for easy recognition). The 9.5mm square section bar ensures the tool sits flat and steady on the tool rest. With the tool parallel to the floor and cutting at centre height the risk of catches and snatches is virtually eliminated. You don’t need to sharpen these tools. When an edge becomes dull you simply slacken the fixing screw and turn to a fresh edge. Easy Wood Tools’ carbide keeps an edge many, many times longer than HSS. These tools can be used to turn dry or green wood and acrylics.
Overall length of 533mm. The shaft is engraved with the corresponding carbide cutter reference number.
Easy Wood Tools are 100% made in the USA.
