Faithfull 24 Plastic Storage Bins with Metal Wall Panel
- Quick and easy way to organise small accessories with easy access
- 24 plastic storage bins with heavy-duty steel back panel
- Shock-proof polymer bins, resistant to mild acids, solvents and oils
- High thermal stability and resist damage from extremes of temperature
- Contents:
- 12 Small Bins (Red): 110 x 100 x 75 mm.
- 6 Medium Bins (Blue): 165 x 100 x 75 mm.
- 6 Large Bins (Blue): 210 x 100 x 75 mm.
- Metal Slot Wall Panel: 660 x 380 x 0.85 mm.
- Mounting screws and wall plugs.
This set of Faithfull 24 plastic storage bins with a metal wall panel is ideal for workshop, garage or hobbies. It offers a quick and easy way to organise small accessories with easy access.
Clearly laid out storage for small parts such as nails, wall plugs, screws etc, and is manufactured from shock-proof polymer which is resistant to mild acids, solvents and oils.
The bins have a high thermal stability and resist damage from extremes of temperature and they are supplied with a heavy-duty steel back panel that can be wall mounted or fitted in to a van.
Contents:
