FEIN 133 HCS E-Cut General Purpose Blade (Starlock)
AX962310
Suitable for wood, plasterboard, plastics, putty etc.
50mm length x 30mm blade width; medium width with waist for optimum cutting speed and swarf removal
Offset blade allows flush cutting
Plunge cutting, Ideal for cut-outs
Starlock mounting for fast work progress and precise results
Increased contact area ensuing maximum power transmission
Compatible with all Oscillating Multi-Tools using the OIS fitting system; FEIN MultiMaster, FEIN MultiTalent, Bosch GOP, Bosch PMF, AEG, Hitachi, Einhell, Makita, Metabo, Milwaukee, Ryobi, Skil, Dremel and others. DeWALT Oscillating Multi-Tools will require an adapter
Suitable for wood, plasterboard, soft plastics, putty etc, these blades will cut to a depth of 50mm. The blade measures 50mm length x 30mm blade width; medium width with waist for optimum cutting speed and good swarf removal. The teeth are ground and hardened and the blade offset allowing you to make flush cuts if needed. Ideal for cut-outs as you can plunge in easily at any point in the material.
The FEIN Starlock (patented) oscillating multi-tool mounting system overcomes the disadvantages found with previous designs. Starlock sets the new standard in the oscillating multi-tool market. The design greatly improves the transmission of torque from the motor to the blade tip. No more wasted power, means faster working, minimised vibration and better results. Starlock accessories are compatible with all OIS and OIS-compatible power tools currently on the market. Looking rather like a crown bottle top, the raised portion of the Starlock snaps into the next generation of multi-tools, making the system truly tool-less.
