Festool AH-ES-ETS/ETSC Positioning Aid For Sander
- Unique accessory, for the ETS 125 or ETSC 125-Li sanders
- Sand perfect edges at any angle between 43° and 92°
- Saves hours of work and results in superior finish
The AH-ES-ETS/ETSC Positioning Aid is a unique accessory, which turns the ETS 125 REQ 125mm or the cordless ETSC 125-Li 18V sander into a dedicated edge sander. The attachment provides a level of control unachievable using any other edge sanding method. Say goodbye to laborious hours spent hand sanding edges. Using this combination, you can effortlessly sand small or large workpieces, narrow or wide edges, from 5 to 60mm, angled edges from 43° to 92°, external curves and you can sand into an internal corner. A large surface support ensures complete stability. There is a choice of sanding modes; Hard, the edge is sanded at the pre-set angle. In soft mode the edge sander adapts precisely to the surface to be sanded, for a gentler action meaning neither paint nor filler is sanded through.
The Positioning Aid AH-ES-ETS/ETSC comes with two interchangeable support plates. The LAS-H-ES for general and the LAS-W-ES with hook and loop for attaching a soft facing when using the attachment on polished or delicate surfaces.
