Festool CTL CLEANTEC MINI Dust Extractor (Bluetooth)
- Touch control panel, easy to operate even wearing gloves
- Fitted with integrated Bluetooth technology
- Automatic on/off with cordless tools using Bluetooth batteries
- Variable speed for matching suction power to task
- T-LOC SYS dock allows easy transport of other Festool tools
- Neat integral onboard hose and cable storage
- Castoring wheels for greater mobility
- Smooth extraction hose improves extractor efficiency
- L class extraction
- Wet or dry extraction (wet requires accessory filter)
The "L" class filters up to 99% of hazardous dust with limit values greater than 1 mg/m³ creating a healthier and cleaner working environment.
The Festool CTL MINI is a compact L-class mobile extractor. It features a high performance turbine and variable suction as standard.
An innovative and intuitive touch control panel makes operating the controls extremely simple, even when wearing gloves. Fitted with integrated Bluetooth technology, it allows you to use the extractor with a remote control or a Festool Bluetooth battery pack for automatic switching-on. Unique access to the main filter from the outside makes changing the filter quick, easy and tool-free.
The Festool CTL MINI includes 3.5m of conical 32/27mm smooth suction hose. This hose greatly improves efficiency. Reduced internal friction increases the airflow rate. The smooth outer skin means you no longer need worry about ribbed hose snagging on edges or inadvertently damaging a workpiece. A CLEANTEC bayonet fitting ensures a secure connection to Festool power tools for sanding, routing, sawing, etc.
The extractor has a flat top, providing space for tools and SYSTAINER cases. The top is T-LOC compatible; SYSTAINER cases lock and stack, for transporting of your other Festool power tools. The castor wheels are lockable. On-board storage for both the hose and power cable keeps everything neat for easy transportation.
The Festool CTL MINI is suited to both dry and wet applications (wet requires a wet filter, not supplied).
Please ensure that any dust extractor is suitable for the type of dust produced before ordering. The L-class is for general work. If you are routing or sanding MDF, manmade boards or all solid woods (oak, beech etc.) you should use an M-class extractor.
The Festool CTL MINI comes with smooth suction hose dia. 27/32 x 3.5 m AS/CT, Bluetooth functionality for extractor, remote switch-on for cordless tools, SELFCLEAN filter bag, hose holder, cable holder and SYS-Dock with T-LOC function.
Please note that 110V machines do not come with a plug.
