Festool CTM CLEANTEC MIDI Dust Extractor (Bluetooth)
- M-class dry extraction, filters dust as fine as 0.1 mg/m³
- Fitted with integrated Bluetooth technology
- Automatic on/off with cordless tools using Bluetooth batteries
- Power tool socket with auto on/off for corded tools
- Touch control panel, easy to operate even when wearing gloves
- T-LOC SYS dock allows easy transport of other Festool tools
- Neat integral onboard hose and cable storage
- Castoring wheels for greater mobility
- Smooth extraction hose improves extractor efficiency
- Wet or dry extraction (wet requires accessory filter)
The Festool CTM MIDI is a compact M-class mobile extractor with high filtration standard of 99.9% hazardous dust as fine as 0.1 mg/m3.
Dust extractors class M are suitable for vacuuming/extracting dry, non-combustible dusts, non-combustible liquids, wood dusts and hazardous dusts with STELs >0.1mg/m³.
It features variable suction and manual filter de-dusting for maximum efficiency. Hose detection automatically adjusts suction to the diameter of the hose in use. An innovative and intuitive touch control panel makes operating the controls extremely simple, even when wearing gloves. Fitted with integrated Bluetooth technology; it allows you to use the extractor in conjunction with a remote control or a Festool Bluetooth battery pack for automatic switching-on. Unique access to the main filter from the outside makes changing the filter quick, easy and tool-free.
The Festool CTM MIDI includes 3.5m of conical 32/27mm smooth suction hose. This hose greatly improves efficiency. Reduced internal friction increases the airflow rate. The smooth outer skin means you no longer need worry about ribbed hose snagging on edges or inadvertently damaging a workpiece. A CLEANTEC bayonet fitting ensures a secure connection to Festool power tools for sanding, routing, sawing, etc.
The extractor has a flat top, providing space for tools and SYSTAINER cases. The top is T-LOC compatible; SYSTAINER cases lock and stack, for transporting of your other Festool power tools. The castor wheels are lockable. On-board storage for both the hose and power cable keeps everything neat for easy transportation.
The Festool CTM MIDI is suited to both dry and wet applications (wet requires a wet filter, not supplied).
“M” class extractors vital when routing/sanding MDF, manmade boards or all solid woods (oak, beech etc).
The Festool CTM MIDI comes with smooth suction hose dia. 27/32 x 3.5 m AS/CT, Bluetooth functionality for extractor, remote switch-on for cordless tools, SELFCLEAN filter bag, hose holder, cable holder and SYS-Dock with T-LOC function.
Please note that 110V machines do not come with a plug.
