Festool Edgeband Storage Holder for KA 65
506233
506233
- Easy to guide the machine, even along long edges
- Recommended for safe guidance of delicate and thin edging
- No risk of damage to long edges
- Max edge length of 8m (edge thickness of 2mm) possible
Using edgebanding longer than 150cm poses the risk that it may drag on the floor and become damaged. The edging holder accessory is designed to avoid this problem by effectively containing a much longer length of material that is rolled up neatly within the holder, resulting in an even feed into the machine. Depending on the relevant thickness of the banding, the capacity of the holder is up to 8m in length and 18-45mm in height.
