Festool MFT/3 Multifunctional Table with Accessories
- Festool quality and precision
- Versatile and Mobile, folds for transport
- Many safe and secure clamping options possible
- Part of an expandable system
- Table size 1157 x 773mm
- Table height 900mm, legs folded 180mm
Axminster Professional Quick Lever Guide Rail Clamp 160 x 60mmFrom £23.28 £19.40
The MFT/3 work table from Festool is part of a comprehensive range of products providing the end user with quality, versatility and, in this case, a superb work holding device. It truly is a multifunction table with many different holding, cutting and machining operations possible. The MDF top is perforated over its entire surface with 20mm holes to take the accessory clamps. These can be adapted to take regular and irregular shaped workpieces up to 78mm thick and 700mm wide. The supplied guide rail and angle stop will provide the opportunity for many different cutting and machining variations when using a portable circular saw or router.
Supplied with table with perforated top and foldaway legs, swivel unit, support unit, angle stop, adjustable stop, guide rail FS 1080/2, deflector FS-AW and additional clamp for securing the stop rail to the V-groove
EAN Barcode | 4014549096420 |
Manufacturer Part Number | 495315 |
Model | MFT/3 |
Nett Weight | 28 kg |
Overall L x W x H | 1,102 mm x 718 mm x 900 mm |
