Festool OSC 18 LI E-Basic Set VECTURO Multi-Tool 18V (Body Only)
- E-TEC motor with electronic speed control
- Long runtimes with plenty of power
- For cutting, sanding, polishing a wide variety of materials
- StarLock Max tool-less, quick blade change
- Includes plunge base, depth stop and dust extraction adaptor
- Supplied with a range of Festool wood and metal cutting blades
- Complete with SYSTAINER T-LOC SYS 2 case
- Body only tool without battery or charger
Work fast and with maximised precision
Achieve accurate results in sanding, cutting and polishing tasks with the OSC. This innovative VECURO system is the answer to demanding tasks that require efficiency and the power to last all day.
Power and efficiency, combined
The brushless EC-TEC motor features electronic speed control, resulting in producing powerful, fast cuts in a variety of materials. Whilst power is at the forefront, the motor consumes minimal energy, providing an excellent battery life. Plus, the benefit of a brushless motor is that it results in less friction, therefore minimising maintenance requirements.
Quick-change system
Saving you time with its innovative Quick-Change System, the OSC allows for rapid and hassle-free tool changes. Securely attach and detach accessories with simply a click thanks to the Starlock Max Tool Holder. Enhance your productivity with this seamless feature, without the need for manual adjustments or additional equipment. It’s a real game-changer.
Comfortable working
When working long hours, you need to turn to a tool that is comfortable and gets the job done smoothly. The OSC has noise and vibration dampening for this exact reason. The anti-vibration system isolates the motor and slimline housing, with an ergonomic rubber grip, resulting in comfortable and controlled handling for the user, for extended amounts of time.
Maximise your precision
With the help of the OSC-AH positioning aid, you can achieve accurate positioning and depth control of the plunge cuts you are making. With the integrated depth stop, it limits the cutting depth of your chosen blade, preventing over-drilling and damage to your workpiece. These features save you time and effort. Without worrying about going too deep, you can focus on the task at hand as the depth stop monitors the cutting depth for you.
Dust extraction
As is the case with Festool 18V tools, dust extraction solutions are always considered. Enhance your safety with minimal interference from dust particles. The OSC-AV dust extraction adaptor lets you connect directly to a vacuum extractor for clean, dust free working.
MyFestool
For your added support, Festool offers a comprehensive service plan once you register your tool. Enjoy the following benefits with the Warranty all-inclusive:
- Free repairs for three years
- Fast resolution directly from Festool
- Replaced in the event of theft
The Festool OSC 18 LI E-Basic Set VECTURO features brushless EC-TEC motor with variable electronic speed control ensuring fast cuts and rapid results in a wide variety of materials. The vibration isolation between the motor and slimline housing along with an ergonomic rubber comfort grip offers a consistently high level of comfort.
The StarLock Max blade changing system is quick and easy, without the need for tools: simply clip-in, lock and go.
The OSC 18 LI E-Basic Set comes with a range of extremely useful accessories. Included in the box is an OSC-A adaptor, which fits onto the head of the tool, allowing connection to other accessories. The OSC-AH positioning aid allows precise positioning and depth control of plunge cuts. The OSC-AV dust extraction adaptor lets you connect directly to a vacuum extractor for clean, dust free working. The OSC-TA depth stop limits the cutting depth of your chosen blade. The set also includes two universal bi-metal blades and a 100mm diameter bi-metal wood sawblade. All components are contained in a SYSTAINER SYS 2 T-LOC carry case.
This is a body only tool supplied without battery of charger.
Benefits
- Includes 36 month machine guarantee
- Full repair, free of charge
- Original parts guaranteed
- 14 day money back
Batteries Included | Body Only Tool |
Battery Type | Li-ion |
Battery Voltage | 18 V |
Corded or Cordless | Cordless |
EAN Barcode | 4014549315965 |
Manufacturer Part Number | 574849 |
Model | OSC 18 LI E-Basic Set |
Nett Weight | 1.6 kg (with battery fitted) |
Oscillation Rate | 10,000 - 19,500 /min |
Oscillation Stroke | 2 x 2.0° |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 94 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 83 dB(A) [3.0 dB] |
Vibration Plunge Saw Blade [Uncertainty K] | 7.0 m/s² [1.5 m/s²] |
Vibration Segment Saw [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
