Festool Spiral Upcut Router Cutters
- High-speed steel spiral cutters
- Very clean cut
- Better plunge cutting
- Less wear and tear on router
- Faster feed rates possible
- 8mm shank
This range of Festool spiral cutters in HSS is suitable for many applications. Spiral cutters offer a superior finish with higher possible feed rates due to excellent chip clearance. Twin flutes ground around the body of a spiral bit help eliminate vibration by spreading the cutting action over a longer edge. With their drill-like points, spiral upcut bits are also better for plunge cuts, decreasing the likelihood of burning the work.
