Festool T-LOC Systainer3 112 Storage Case (SYS3M)
- H 112mm x L 396mm x W 296mm
- Durable and reliable with excellent functionality
- Cases lock together using the T-LOC central controller
- Be better organised, with greater protection and easier mobility
- Fully compatible with all previous Systainer generations
- Front swing handle allows you to carry the weight close to you
- Systainer³ is a complete, highly practical storage and transport system
The latest generation of Systainer³ cases enable you to be better organised, more mobile and work with greater efficiency. Systainer³is a complete and highly practical storage/transport system. Developed in conjunction with TANOS and bott, Systainer³ is the perfect answer to safe storage and easy transportation. Precision made for durability and reliability these cases are of the highest quality. They offer simple handling, high functionality and robustness. Be it in the workshop, on site or part of a mobile system in a vehicle, these cases provide the solution. Front swing handle design.
The cases lock together using the T-LOC central controller, they close, open and connect using a single movement. Systainer³ cases connect with one another and are fully compatible with all previous Systainer generations, mobile dust extractors and many other system accessories.
Fitted with front swing handles, Systainer³ cases are ideal for transporting in vehicles and make it easy to remove the Systainer³ from a shelf system. The front carrying handle allows you to carry smaller cases close to the body.
