Festool UG-KS 60 Base Frame for KAPEX KS 60
103643
From £424.98 £354.15
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • Portability with stability
  • A complete mitre saw workstation system
  • Simple attachment of the KAPEX KS 60 to the base frame
  • Quickly folds down, mitre saw remains attached
  • Large diameter wheels for easy transportation over rough surfaces
  • Levelling feet for use on uneven surfaces
  • Comfortable working height of 900mm
  • Right and left hand extensions are also available
With the UG-KS 60, you can turn your Kapex KS 60 compound mitre saw into a complete mobile, mitre saw workstation. The combination is practical and robust resulting in portability with stability. The UG-KS 60 greatly increases the flexibility and versatility of your Festool sliding compound mitre saw. Attaching the KAPEX KS 60 to the base frame is very simple, and the mounting plate features convenient, safe storage for a spare saw blade. There is no need to remove the saw for transport; the saw and base are very compact when folded down. Two large diameter wheels make it easy to move the frame over rough surfaces or up kerbs or steps. The folding support frame doubles up as a handle for transporting the machine. Set up is extremely fast and easy and levelling feet ensure complete stability on uneven ground. Once set up the working height is a comfortable 900mm.
Right and left material support extensions with measuring scales are also available.
