Festool TCT Saw Blade Universal - 254mm x 2.4mm x 30mm 40T
107045
107045
- 40 teeth, 254mm(10") diameter, 30mm bore
- Universal blade for fast, clean cuts
- Designed for cutting solid wood cross cuts, blockboard, plywood
- Cuts multiplex/multi-layered wood, raw chipboard, MDF and HDF
- Generous carbide tips ensuring a long working life
These 254mm (10") blades fit the Festool TKS 80 sawbench, but can of course fit any saw that takes this size of blade.
This 40 tooth universal blade produces fast, clean cuts. The tooth format and cutting angle is particularly suitable for cutting solid wood cross cuts, blockboard, plywood, multiplex/multilayered wood, raw chipboard, MDF (medium-density fibreboard) and HDF (high-density fibreboard).
Festool TCT (tungsten carbide tipped) circular saw blades offer a perfect combination of cutting performance and quality results. The blades feature colour coding for easier selection of the correct saw blade.
