Festool TCT Saw Blade Fine - 254mm x 2.4mm x 30mm 60T
107043
From £107.78 £89.82
  4. Empty Star
1 Review
  • 60 teeth, 254mm(10") diameter, 30mm bore
  • Cross cut blade for splinter-free, clean cuts
  • Designed for cutting solid wood cross cuts,veneered boards,
  • Cuts parquet, hard PVC, blockboard, plywood, acrylics and MDF
  • Generous carbide tips ensuring a long working life
These 254mm (10”) blades fit the Festool TKS 80 sawbench, but can of course fit any saw that takes this size of blade.
This 60 tooth crosscut blade produces clean splinter-free cuts. The tooth format and cutting angle is particularly suitable for cutting veneered boards, parquet, hard plastics, hard PVC, solid wood cross cuts, blockboard, plywood, multiplex/multi-layered wood, acrylic glass and MDF.
Festool TCT (tungsten carbide tipped) circular saw blades offer a perfect combination of cutting performance and quality results. The blades feature colour coding for easier selection of the correct saw blade.
3.00 1
