FISCH 25 Piece HSS Brad Point Drill Bit Set
- Extremely resistant: high quality HSS hardened to 62 HRC
- Ground centre point and spurs for precise positioning and clean cut
- 1 to 13mm in 0.5mm steps
- Smooth chip ejection, smooth, ground spiral
- Suitable for drilling in soft and hard wood, glue-laminated boards, MDF etc
- Use for drilling plastic and acrylic glass
- Robust high quality case gives easy access to individual drills
Axminster Workshop Dowel Drill Stop Collar Set 3 (6, 8 & 10mm)From £2.38 £1.98
The 25-piece HSS drill from FISCH® is suitable for drilling into hard and soft wood, MDF and other manufactured boards. They have a precision ground point with twin cutting spurs for precise positioning and a clean cut. Made of very resistant high speed steel to EN ISO 4957 with a hardness of approximately 62 HRC, these drills give you very good and precise results. Their cylindrical shanks allow their use in all common battery operated and hand-held drilling machines as well as in vertical and bench drilling machines. The drill set covers a diameter range from 1 to 13mm in 0.5mm steps. Sizes 1mm to 2.5mm are standard twist drills, with 3mm to 13mm being brad point drills.
EAN Barcode | 9002696360391 |
