freud Flush Cutter Top Bearing - 1/4" Shank
From £24.58 £20.48
2 Reviews
  • Top bearing cutters ideal for template profile work
  • Bearing follows a pattern fixed above workpiece
  • Perma-SHIELD® coating helps minimise resin build-up
Also known as template profile cutters, these bits leave a perfectly crisp, neat finish. The bearing is the exact same diameter as the cutter itself, making these bits highly useful for template work with the bearing following a pattern fixed on top of the workpiece.
freud has over fifty years experience in producing high quality tooling and router cutters. With a freud router bit you are assured of high precision and outstanding performance. Each cutter has a Perma-SHIELD® coating. This superior non stick feature prevents the adhesion of resins, giving a really clean cut and finish. Careful selection of tungsten carbide ensures the bits offer a perfect finish and a longer, sharper lifetime.
5.00 2
