Ice Bear Japanese Oire Nomi Chisels
- Laminated blades with edge hardened to over HRC 65
- Traditional red oak handles with steel hoops
- Overall length approximately 230mm
Ice Bear Japanese Combination Waterstone - 1,000g/6,000gFrom £19.88 £16.57
Made in Miki City, Japan by master blacksmith Ioroi, oire nomi are used by Japanese carpenters and cabinet makers. These chisels have a blade length of approximately 62mm(2.1/2") with longer shoulders and tangs. They are well balanced and will take a blow from a hammer for heavier work as well as taking the thinnest of paring cuts for fine work. The overall length is approximately 230mm(9"). These professional grade chisels are forged using high carbon steel (Shirogami White Paper #2 steel) laminated to a softer low carbon backing steel. They are hardened to over HRC 65 and will hold a razor edge for far longer than an equivalent western chisel. They feature red oak handles, fitted with steel hoops finished with a mushroomed top ready to go.
Chisel Blade Length | 62 mm |
Overall Length | 230 mm |
