Power Grip Japanese Carving Set 5pce
951147
From £25.88 £21.57
52 Reviews
In Stock - Ready to dispatch
  • A quality 5 piece Japanese detail carving set
  • Good choice of profiles; honed and ready for use
  • Neatly contained in a storage box
Get set to carve
Looking to carve straight out of the box? Then this 5 piece Japanese detail carving set is for you.
Razor sharp
Experty honed, this quality Japanese carver’s set is razor sharp and ready to carve straight out of the box. The steel blades are hollow ground for easy sharpening and hold their edge very well, maintaining quality cuts and precision everytime.
Finer details
This detail carving set offers a range of useful chisels for all manner of detailed carving. The set comprises an 8mm skew chisel for getting into tricky spots, 8mm curved chisel, 6mm vee tool for outlining lettering and leaving a clean crisp edge, 6mm gouge and 3mm veining tool for adding detail or texture.
Shaped for comfort
The chisel handles have been designed with comfort in mind. Shaped to fit comfortably in the hand, the handles also feature a flat edge to prevent them from rolling off your workbench.
A great set of detail carving tools from Japan. The steel has excellent edge holding properties, precisely ground and honed ready for use. The chisels contained in the set are hollow ground for ease of sharpening. Nicely shaped hardwood handles fit comfortably in the hand and, adding a nice touch, is a flat area on the handle to stop them rolling off of the bench. Set contains 8mm skew chisel, 8mm curved flat chisel, 6mm vee tool, 6mm gouge, 3mm veining tool.
4.80 52
