Z-Saw Japanese Dozuki-Me Tenon Saw - 240mm
110050
110050
- For extremely precise and accurate cuts
- Fine blade supported by a steel spine
- 26tpi, 240mm blade, 50mm depth of cut
Axminster Workshop Centrotec Compatible Depth Adjustable Bit HolderSpecial Price £3.98 £3.32 was £6.98 £5.82 Save £3.00 £2.50
Show more
Show less
For extremely precise and accurate cuts. The blade is supported along its back by a steel spine giving a 50mm depth of cut. In addition to a standard replacement blade, is a wide blade for deeper cuts (72mm). Both blades have 26tpi, are 240mm long and 0.3mm thick.
Blade Thickness | 0.30 mm |
Length of Blade | 240 mm |
Overall Length | 540 mm |
Tooth Pitch \ tpi | 0.96 mm \ 26 tpi |
#AxminsterTools
