Japanese Free-Way Coping Saw - 130mm Throat
502229
From £9.88 £8.23
  5. Half Star
37 Reviews
  • Buy 10 for £8.89 £7.41 each
  • Buy 20 for £7.90 £6.58 each
  • Buy 50 for £6.91 £5.76 each
  • Spiral tooth blade allows you to make cuts in any direction
  • Case hardened blades resist breakage and wear
  • Each saw is supplied with two spiral blades
  • Frame also takes standard coping saw blades
  • Maximum cutting depth 130 mm; blade diameter 1 mm
The Free-Way saw is a quality tool, made and designed with attention to detail. The frame puts the correct amount of tension on the blade and the clamps will take standard coping saw blades. The spiral blades fitted in this coping saw work in the same way as a standard coping saw. However, the spiral-tooth saw blade allows you to make cuts in any direction without turning the saw. The case hardened saw blades are highly resistant to breakage and wear. Each saw comes with two spiral blades. The maximum cutting depth is 130 mm and the blade diameter 1 mm.
4.40 37
